xperia e4 OTG?
stvs
xperia e4 OTG?
today i bought the e4 model with OTG cable but
when i plugged in my usb stick memory 8 GB t nihe device couldnt see that drive at all
no sign no notifications nothing like a dead usb stick( btw my stick works well on my tablet OTG..
so does the e4 really support OTG or not? tnx
Uliwooly
@Avvoider
It doesn't support OTG
12 REPLIES 12
Jake-SonyXperia
Champion
Hi stvs,
Discussion Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
What format is the USB drive in, Fat32, NTFS or Exfat
stvs
ops pls delete my post as "stvs1" my bad,, so i have to add that e4 seems cant give any power to usb drive (it has a mini blue light if it powered)
stvs
bad news i went to the store that i bought e4 and the tech stuff informed me that the xperia e4 doesnt support OTG Slightly_frowning_Face
Batoo76
sorry for typing errors, I should have reread.
Repost in readable text :
I have the OTG problem too, no hardware recognition of my PNY O3 USB drive. The phone does not detect it, and the mount option in storage parameters remains very and not selectable. As it does not mount, can't be the drive format problem. By the way, mine is fat32 formatted.
pierrerudaz
Same problem here, I can't connect a USB key.
I read somewhere that E4G has OTG
Could someone from Sony confirm this?
friends
Hey i also hv same problem... I hv xperia e4 n it doesn't support otg.. Nothing happens when i insert cabel in my phone.. Tell me what to do??
Ulfaa
Plis upgread sony xperia e4 dual USB OTG
Avvoider
Hello. I'm planning on buying a gamepad. I'd like for it to be compatible with both PC and Android devices.1st question: does the Xperia E4 support OTG? 2: will a gamepad with Bluetooth work with the phone? Basically what do I need to look for in the gamepad. Thanks in advance.
Tags (4)
Uliwooly
@Avvoider
