i'd got a E5 and miss a few. I'm not fluent in english, sorry.
1. need a file/datamanager for installing software locally (no internet connection wanted)
2. where are the geman letters ä, ü, ö at keyboard?
3. is it possible to get support in german language?
Tx forward for your answer.
gucky_66
@gucky_66 wrote:Hi,
gucky_66
1. Files manager like File Commander usually is installed default in smartphone. If you don't like it, you can install from Google Play any others which you want.
2. In your smartphone settings (language section) usually you can choose language which you want, automatic is changing and text language (letters and ect)
3. You can get support in German language here (choose your location/language)
If you have trouble with English, you can use Google Translator which can help you
tx for the answers, but i don't need help for changing language in smartphone. This was only for the forum.
In my smartphone i'd change to german. 🙂
i'did not found any file-/datamanager in the apss in the e5. And, btw., i will not going online anytime (also google-play).
That's the problem.... Hope, one of you can solve this and tell me, how-to..
greetz
