Sudden Death
PingPong_101
Sudden Death
HELP!!!
My sony xperia E3 went completely black, like completely dead.
I was charging it when I went to check the battery status, it was off. I've tried everything that's on the internet, from the xperia companion to the pressing of the power button together with the down volume button... But nothing works, the LED light doesn't even light up, the computer doesn't recognise it.
Someone please help
Uliwooly
You will have to contact your Local support
2 REPLIES 2
Uliwooly
Ram9
It happened to me also. In experia open the cover u will find a small very small indeed button. Just on it with any soft particle like tooth pick. Ur phone will reboot
