Greeting.
I'm interested, how do I change the 'design' clock on the locked screen.
Currently it looks like this.
Advance grateful for the help.
enable lockscreen widget under settings-security, after that at the lockscreen swipe to left and add another clock widget and delete this one.
forget that "press the clock for a while" thing
Nothing...
When I do that, let me 'Alarm & clock'.
What now?
that doesn't make sense, on the lock screen > long press the clock, it should give you options to sitch the clock
Nothing is happening.
No, I have a pattern lock.
