I have a problem. My Xperia E3 turn of the screen during the calls even if i am not talking with it in my ear and do not let me cancel the call until the answer machine close the call. How can i solve it?? Please help. And thanks
Hi Teffi,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Can you advise if you are using some screen protector or case on that device?
These may very well be affecting the proximity sensor of the device, if so I suggest trying to remove them and then testing it.
Please let me know.
Btw i plug the charger and does not worrk neither
Hi Teffi,
Please let me know.
Does not work
Thanks my dear friend. The screen Protector was the problem. Then it means i can not use screen protector?
Thank you but how I know which is properly without spend my money in vain?
