Does anybody know if the Xperia E supports usb otg and if so how do I enable it.
Xperia E does not support USB OTG. Some models however support the USB-host standard but I tried the Xperia E with a USB-host adapter and I didn't get that to work either.
What are your thoughts about this forum? Let us know by doing this short survey.
Alexander,
Do you know if OTG is not supported because of a firmware lock or because the hardware is not there. I would have thought the hardware would be similar for the E and S (which I think does support OTG)
or any other way..............
xperia E ,C-1504 single sim is not support duel pen drive socket give me solutions to support the duelpendrive in my phone
Xperia E doesn't support USB OTG.
Unfortunately USB OTG is not supported in Xperia E. I don't have any more information of why it's not supported.
I want to know if xperia e1 dual supports dual pen drive,if yes please tell me how i can connect it to e1 dual.
I don't know why Sony Xperia E4 dual and such other modes do not support OTG. Can Sony explain this?
Sony, please give us solution.
