D2203 MOBILE NETWORK STATE - DISCONNECTED
Tgunz
Hi people. I have no network. My Service State says Radio off. Having dialled *#*#4636#*#* it refuses to change from LTE/GSM auto (PRL) and it will not turn on radio. As a result i have no network connection. Please help
8 REPLIES 8
NeoBeum
Enthusiast
There's a bit of a lag when it changes on/off.
What does Service State report in About Phone?
Uliwooly
@Tgunz
have you rooted the device? has this phone ever worked?
Tgunz
Rooted the device? How do I do that? Yes the phone was working before.
Service State reports voice:radio off data: radio off. I have tried several times to switch it on n it will not budge.
Uliwooly
@Tgunz
My question is if you have done anything to the phone like installing a custom ROM, rooted the device, etc
Tgunz
No. When the problem started i updated the operating system in hopes that this error will clear yet nothing. Every other functiom works fine. Its just that it refuses to select for example GSM only. Every selection i make it immediately switches back to LTE/GSM auto (PRL)
NeoBeum
Enthusiast
Can you perform an Antenna Test in Service Mode?
Tgunz
How do i do that?
Tgunz
Im in Service mode but no antenna test
