5 fingers?
thejavigames
5 fingers?
Good morning , because the xperia e4 detected puts 4 fingers , but actually detect Now Detects reason 5 for 5 for an upgrade or because information about the 4 esta erroneous ? please do not lower it to 4 if it was updated 5
I forgive my English , but I speak Spanish
21 REPLIES 21
Uliwooly
@thejavigames @xperiaperson
There's a glitch with that app, check this out
www-support-downloads.sonymobile.com/e2105/whitepaper_EN_e2104_e2105_xperia_e4.pdf
Input mechanisms
Text input On-screen QWERTY keyboard
Touch screen Capacitive
Touch gesture Yes – multi-touch, up to 4 fingers supported
thejavigames
I think it's not a glich , according to box my xperia is the rev2 , according to e read some xperia e4 have problems with touch when playing or writing, rev2 and seen none has that ruling , till the test one mediamark detect five fingers, I detected any application 5, and 5 randomly moving them , any application that uses detects me 5 fingers , so my question is that on the web, and pdf 4 when said detecting detects 5 .
My concern is that we have the rev2 , we go down to 4 fingers and suffer the problem of touch
forgive my English I use google translator Spanish
Uliwooly
Again, the info above comes from Sony's official white paper.
thejavigames
If it is , the paper says 4, but I ami detects 5 , you have the xperia e4 ? I commented that if it detects 5 rev2 deveria correct the information from the web as many people backing down when you buy if you have fewer fingers , but mostly for the accuracy
Uliwooly
@thejavigames
I don't understand your logic, the phone was not advertised as such (5 fingers).
where do you get this information? is it a fact or your opinion?
@thejavigames wrote:
... as many people backing down when you buy if you have fewer fingers ...
thejavigames
I do not understand if I guess not by the translator ,
e4 xperia itself as sensing 4 fingers .
but actually it detects 5, at least my xperia e4 and rev2 and those tested in stores.
http://www.gsmarena.com/sony_xperia_e4-6882.php
Four fingers , my xperia e4 detects 5 .
I ask that because it puts 4 if indeed detected 5, have a xperia e4 to prove ? that rev you?
Uliwooly
@thejavigames
I've escalated this and you will get an official statement, again, its on the white paper, I'm trying to help you here there's no need to antagonize me, I just want to know where do you get this info:
thejavigames
I will try to explain as best as possible ,
Many people believe that the more forums fingers is more accurately detected in many videos playing touch failures for example gta san andreas, blame the 4 fingers , I had a terminal 2 and worked detected only fatal to write fast .
at least seeing the comments on youtube and my experience with 2 fingers if it affects the sensitivity , only if you write fast by whatsapp , also it affects gestures google maps, although I guess it will be more quality tactile fingers .
ejemple:
https://www.youtube.com/watch?v=42adgBU80NI
coment acuse xperia,
https://www.youtube.com/watch?v=Eubv9ho8ULQ
ami me five fingers and detects these failures have not commenting on youtube and forums,
but I worry that sony back down to 4 fingers and the failures that have rev2 is by youtube.
I try to explain as best as possible not speak English
mi xperia detect 5 figers, no problem touch, you test 5 fingers or 4?
Tags (1)
Hampus
Champion
Hi thejavigames,
Sony Xperia E4 is designed and supported with multi-touch up to 4 fingers. I have tried the application that you've mentioned earlier and yes, it can in some cases detect 5 fingers but it doesn't work especially good. Therefore, we can only guarantee that it will work with multi-touch up to 4 fingers as stated in the white paper.
thejavigames
Hello, good ami me and I have no detects 5 errors , 5 moving works perfectly together .
