Good morning , because the xperia e4 detected puts 4 fingers , but actually detect Now Detects reason 5 for 5 for an upgrade or because information about the 4 esta erroneous ? please do not lower it to 4 if it was updated 5
I forgive my English , but I speak Spanish
Hi thejavigames,
Sony Xperia E4 is designed and supported with multi-touch up to 4 fingers. I have tried the application that you've mentioned earlier and yes, it can in some cases detect 5 fingers but it doesn't work especially good. Therefore, we can only guarantee that it will work with multi-touch up to 4 fingers as stated in the white paper.
Which app or apps did you used to test this? and why do you need so many fingers?
Before had another phone with just 2 clicks and malfunctioning , google maps became crazy , wrote the fatal keyboard, hope you never fall to 4 taps and stop at 5,
but that puts reason that detects 4 if actually detects 5 ?
I personally prefer 5
That doesn't explain nor answer the question. which app/game requires 4 or 5 fingers?
It is not that, but that fewer fingers = less sensitivity at least in my mobile old
Not quite, and also, after checking the Xperia E4 support up to 4 fingers.
mi e4 2105 detect 5 fingers, pliz no update downgrade to 4
I'll escalate this perhaps I can get an official answer. Which app are you using to test it?
