Hello, This is my problem.
I bought the Xperia E like 1 month ago, everthing was fine until about a week, the phone started to lagged a lot, the games close by themselfs, so I checked the memori and I saw that the RAM has like 20 MB but I didn't have anything open, I move all the apps I could to the internal memory instead the phone memory, but it didn't work. I download an app to optimize the memori (memory booster) but that worked a little, until 3 days ago when I realized that the Ram was in 0!!!
Please helpme, I don't know what to do, I have not dowloaded a lot of apps, just a couple of games, a translator, and something for music, and an Antivirus (Avast) . Now I can't even chat relax because even the keyboard takes a lot of time to show up.
Thanks, if you can help me I would really appreciate.
PD: Im sorry if my english isn't perfect, i'm from Colombia
if that doesn't work, repair your phone with either SUS or PCC, its an app acting up using up all your RAM
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget the Kudos
the more apps that you have running in the background the less free RAM you will have, uninstall this apps
Taskillers
task managers
antivirus
ram apps
booster apps
battery apps
this apps will drain your battery, use up your ram, slow down your phone, and create other issues. if you have apps that you don't use, uninstall them, if they were preloaded, disable them.
Don't forget to give kudos
thanks I will try, but after all, is not a little exaggerated have 0 Ram, is not wierd? It couldn't be anything else?
thanks again men
Bridge (for Mac)
Ok thanks, it worked I use the PC Companion that I had already installed, and the I turn off an on the phone.
Now the phone shows me 175 MB of RAM, I don't know if it is normal but it's better than 0 eh?
But because of that I wonder how much Ram is it normal to have? Could you tell me how much ram normaly you have, for example when you got none app open and when you got a couple of apps
The amount of Free RAM and Internal storage varies, some countries / networks have few extra apps so there isn't quite an standard.
ok thanks again men!!!!
