The LCD Screen on my DCS-HX200V has the message "Point camera at yourself to start timer" and a small incert screen I cannot get rid of. I do not recall attempting to use a timer.
Hello Dijcann - Welcome to the Sony Forums
You may have accidentally activated the Self-Timer mode when trying to take a photo. It can be turned on/off by following these instructions in the user guide:
http://esupport.sony.com/docs/dvimag/DSCHX200_HX200V_guide/en/contents/02/04/05/05.html?search=timer
'Single Shooting' mode is the one that you are probably looking for.
Thanks,
Simon
Thank you. Problem solved.
David
