Will the Memory Stick Pro Duo card - 4 GB fit in my Sonycyber-shot (7.2 megapixel) camera?
Best thing I can recommend is jumping on http://Sony.co.uk/support and type in your model, there should be a memory card compatibility section there for you to check and any limitations you may encounter.
If you have difficulties, please could you post your model which should start DSC- and I will have a hunt.
I have a DSC-P200.
Thanks
