DSC-W560 trouble
profile.country.sr_YU.title
zadrugar
DSC-W560 trouble
on my camera is something strange going on. I would like to re-load the software of the camera.
does anyone know how to do it _?
Tags (1)
profile.country.en_GB.title
Mick2011
Hi zadrugar, welcome to the Sony Forums :slight_smile:
There isn't an available firmware update, according to the W560's download page. However you should be able to fix most glitches by resetting the camera to factory defaults.
Go to [MENU] > [Settings] > [Main Settings] and select Initialise.
Hopefully that will cure the odd behaviour.
Mick
1 REPLY 1
Mick2011
Mick
