I have been looking for a downloadable version of the iManual for the DSC-HX20V. I have found that for some products (TVs for example), there is a zip version of the iManual that can be downloaded and read offline, however, I can't find a zipped version of the iManual for the HX-20V, I can only find the HTML version.
Does a downloadable version of this exist?
Hi jamger and welcome.
You can download a .PDF version of the manual from here: -
http://pdf.crse.com/manuals/4419606111.pdf
Biencogo,
Thanks for the reply.
The link that you've provided is for the standard manual that comes with the camera. I was looking for a downloadable version of the online i-manual that has far more information in it.
Regards.
I don't think this is possible - it is an online manual after all.
Every item is a separate link to a web address.
It seems that for some products, there is an offline version.
If you go to this link for example:
http://www.sony.co.uk/support/en/product/KDL-32EX403
There is a zip version of the i-manual that can be downloaded and you can then extract it and browse the manual offline.
