Connecting a handle mount Metz flash on a Sony Cybershot DSC-R1
profile.country.fr_FR.title
jllbvs
I bought in december 2006 a Sony Cybershot DSC-R1, and I have been using it during these 6 past years with the greatest satisfaction.  The DSC-R1 is an excellent camera, which perfectly fulfills all my needs.
With it, I use a Sony HVL-RLA ring flash for close-up shots, and a HVL-F32X. (I always encountered some contact problems with the flash socket, but that is another story).
With all my films cameras (Rolleiflex FX, Rollei SL66SE and Linhof large format camera) I have always been using a handle mount flash Metz 45 CL-4, which I highly appreciate.
One of the advantages of this kind of flash is that it can be used practically with any brands and models of cameras, just by using what is called an "SCA" adapter. On Rolleiflex medium format film cameras, the SCA 356 adapter performs perfectly.
The same flash can be used on digital cameras. I recently  installed the flash on a Fuji X100 with a SCA-301 system module, SCA-300 adapter and PC synchro cord. It works perfectly.
So, I decided to use the Metz 45 CL-4 with my Sony DSC-R1. Metz knowledge base confirms that this flash can be used with a DSC-R1. No problem.
Then, I bought a SCA-3602 (dedicated module for Sony cameras), and a SCA-3000C adapter. Following instructions of DSC-R1 user manual and Metz user guides, I tried to configure the system.
Nothing. I checked all carefully, assembled and disassembled it a dozen times : nothing. No flashlight...
There is probably a small detail which I forgot. But which one ?
I know that the SCA-3602 is out of production. But, the one I bought was a brand new one, so with the SCA-3000C.
Did someone already tried this system, or experienced similar problems ?  Please, help !
Many thanks and kind regards.
Jean-Louis
Tags (4)
jllbvs
Hi everybody.
I received this morning the new SCA 3602 M4 adapter.
I mounted it under the SCA 3000 C-M1, plugged both cables : all functions perfectly.
Perfect flash exposures in TTL and automatic (aperture) modes.
I also tried the 45 CL-4 in indirect mode. Also OK.
The camera controls the flash completely.
Well, I guess that the SCA 3602 "version" was the problem.
With the first SCA 3602, nothing. And with the second one (with the "M4" green label on top) all is OK.
Many thanks to all those who answered to me.
If one day I can help you, it will be a great pleasure.
Have a nice day.
Jean-Louis
12 REPLIES 12
profile.country.en_GB.title
blaireau_photo
Hello Jean-Louis :slight_smile:
Unfortunately this isn't something that I have personally done before. All I can recommend is checking the latest version of the user guide in question which I have found below:
http://www.manualslib.com/manual/102781/Metz-Sca-3602-M4.html#manual - SCA 3602 Manual
I notice that there is some brief troubleshooting information on page 22 which may be of use to you.
Is there any activity at all with the flashlight i.e. does it appear to be partially lighting up?
Hopefully another forum user has tried something like your combination in the past and will see this forum thread. I am also going to show this question to a contact of mine to see if they can offer any further advice.
Thanks,
Simon
Message was edited by: blaireau_photo
jllbvs
Many thanks for your help, Simon. Next saturday, I'll check all this again.
Kind regards,
Jean-Louis
blaireau_photo
Hello again :slight_smile:
I have been discussing this with a contact of mine (the very knowledgeable Mick2011 actually!) and he also pointed out that the SCA3602 adapter has a minijack connector that needs to be connected to the camera's ACC port as well - were you already aware of this?
Simon
jllbvs
Of course, yes, I did it. It is the only way to connect the SCA3602 to the camera, as the adapter's foot has no contact for the camera's accessory shoe. The SCA 3602 is connected to the camera by this cord, and the SCA3000C is connected to the flash.
Jean-Louis
profile.country.de_DE.title
cmosse
Contributor
Have you tried to swtich the selector on the rear of the SCA adapter to position B (or A) - see manual on p.6?
Note: The switches and the indicator are concealed behind a cover at the rear of the adapter. To open use a fingernail.
jllbvs
Yes, I did it also. And that's the problem. I tried everything described in the 4 manuals : DSC-R1, Flash Metz, SCA 3602 and SCA 3000C...
blaireau_photo
Thanks for letting us know about your progress with this.
It may be worth getting in touch with Intro 2020 Ltd who state on their website that they are the sole importer of these products into the UK. In their position, they may be able to offer further advice about compatibility with your DSC-R1. Their contact details are on the following page:
http://www.metzflash.co.uk/pages/contact.htm
Thanks,
Simon
jllbvs
Many thanks for your help.
I send an e-mail to metzflash.co.uk, explaining the problem.
I have only noticed these details :
  • I live in France, where I bought (about 12 years ago) my Metz flash.
  • The SCA 3602 and SCA 3000C were both bought in the USA.
  • The SCA 3000 cable is labeled "SCA 3000 C-M1"
  • My 3602 user guide is labeled "Sony SCA 3602", and not "SCA 3602 M4", like all the notices found on websites.
  • On its last page, I read "Sony - DSC-F707, DSC-S85, DSC-S75, MVC-CD200"
I don't know if all this has some importance. But it's the only thing I can point out.
Kind regards,
Jean-Louis
scav242
Hi
This might be of help http://www.flickr.com/groups/sonydscr1/discuss/72157603747678345/
seeing as someone is using the same set-up successfully
Message was edited by: scav242
