Cannot Upload by wifi to MacBook - RX100 vii
fishhoek49
A newbie - forgive me.
RX100 vii send to Smartphone OK.
Will no send to my Macbook.
Set USB to Mass storage (then tried again with USB to Auto).
Wireless Auto Import: Set Computer when asked and set a storage location.
Tried to send photos to MacBook using wifi - send to computer option.  Message is that device and location are not set, says to connect usb to computer and set.
But when I connected the message says cannot set device / location until I disconnect the USB cable.
I'm stumped.
I'm stuck.
Tags (3)
6 REPLIES 6
HannahEd01
profile.country.NL.title
Strampke
Creators' cloud doesn't match.
Here is a compatibility list for Imaging Edge and Creators'cloud
Maybe you can find some relevant information about Imaging Edge and Mac over here.
Additional reading.
Hope this helps you find a solution.
danardeng
Contributor
How are you trying to send images to the macbook?
Transfer by wifi is supported with imagingedge mobile, not with desktop.
fishhoek49
Many thanks - I can update to phone but haven't cracked uploading to MacBook.  Play Memories does not support the version of OS I use - Big Sur .
fishhoek49
Many thanks for taking time to respond.  I will look at your suggestions.  Play Memories Home won't work with Big Sur - the OS on my MacBook.
fishhoek49
My thanks for this I will look at the links - wasn't aware of creator cloud.
