Can I use the battery charger for my DSC-T90 in the USA using just a travel adapter? Or do I need a transformer too?
Hi Ollies-Guardian and welcome.
You will be OK just using a plug adapter as the charger operates between 100 and 240 volts.
Here is Page 162 of your manual: -
Hi Ollies-Guardian,
welcome to Questions & Answers..:smileyhappy:
Yes you should be fine, I have charged my cameras, mobile phones, using a plug adaptor in several different countries without any problems..
Thank you very much.
You're welcome Ollies-Guardian..:smileyhappy:
Thank you very much. I can go on holiday re-assured.
