Xperia C Hang Problem
tiwarialok
My new Xperia C shuts down upon receiving call. I can hear one ring and the phone goes off. I have to restart it manually. It doesn't happen with every call but once or twice a day. I really hope Sony offers some solution.
15 REPLIES 15
viv-c
Am using Xperia c- its getng hang instantly.. Just 1.mon
th old wot should i dø ??
profile.country.RO.title
_alexdon_
Do you have task killers,antivirus etc?
alexdon
onetimeuser
I facing the hang problem with xperia c. It hangs occassionally and the problem is increasing. Waiting for a solution
theRK
sometimes when i call someone then the phone all functions are working except call,screen lock button.
at that time the phone is not shut down as well as  not locked by pressing the lock key and incoming and outgoing calls also i am unable to use.
how to restart the at that moment without open the cover of phone and reset it.
plz help...
merlyn
 Cant read the solution
30396543
Mobile hang problem
