Hi
I cannot find file manager of my sony mobile.
Hi @kakanajaf, welcome to our forum!
Depending on the software in your device, there may be a File manager called "File Commander" that is pre-installed, otherwise you can take a look in the Google Play store and see if you find any File manager there!
I hope that helps!
