Got my xperia c4(E5363) this afternoon and noticed an issue with the proximity sensor. When I make a call and bring the phone near my ear, the screen becomes black BUT it does not recover even when I take the phone away from my ear. It remains black only. Even pressing the power button does not help.
The only workaround is that I have to remove the sim, which causes the phone to reboot. Once its up, I need to shut it down again, re-insert the sim and restart.
pls help !!!
It could be related to the screen protector,this has been noticed in the past on other devices. Now I can't force you to take it down.
Can you check if the same occurs in safe mode?
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Also,do you have a screen protector or a flip case?
Thanks for your reply.
I tried the safe mode and still have the same problem.
I am using a screen protector
yeah, that could be an issue. Anyways, given that I got the handset only yesterday afternoon, so I'll take it to sony repair center before removing the screen protecter. cheers.
just back from service centre. you were right. it was the screen protector !!!!
It has been removed and the phone works like a charm now.
Many thanks for your help !!!!!!!
Great,enjoy your device.
