Ultra TV
RISOLTO
DAVEHF71
Nuovo
Ultra TV
I have KD-49XF90xx Android set, will I be able to receive Ultra TV now that I have SKYQ. I followed the onscreen instructions but with no result.
Regards
Dave F
1 SOLUZIONE ACCETTATA
Soluzioni accettate
DAVEHF71
Nuovo
Hi
I would like to thank the two people who have helped with my problem about ULTRA TV. Having followed their advice when I go to the screen format button it comes up 3840x2160p  and the picture is superb
 Many Thanks
Dave
4 RISPOSTE 4
royabrown2
Eroe
@DAVEHF71
Can you please better describe ‘no result’?
No UHD, just HD?
Or no picture at all?
What happens if you start the BBC iPlayer and watch His Dark Materials? Does that play in UHD for you?
DAVEHF71
Nuovo
Hi
Thanks for your help. I have gone to BBC I player and then His Dark Materials, the program has started and the picture quality seems very good, how do I tell if this is ULTRA. as you can tell my  knowledge of these sort of things is limited. I am of that age.
Once again many thanks
Dave
Pentium_Gladio
Specialist
The resolution for UHD is 3840x2160. You can find it by pressing the "i+" button next to the "0" button on the remote.
Pentium_Gladio
DAVEHF71
Nuovo
Hi
 Many Thanks
Dave
