Power ECO settings
Paul_Glover
Power ECO settings
Hi read the posts on TV going off randomly and the Idle setting
My problem is the reverse I want the TV to shut down after 1 hr non interaction
This until recently worked well with a shut down notice appearing before going into standby
Now this setting changes to idle off  without interaction from me
I set eco to High and 1hour idle  this changes I come out of the menu using back I can go straight back in and the setting is how I left it However after the TV DOES NOT IDLE after 1 hr I check the settings and power saving is off and idle is off
I am the only one here   Up until now this has worked well does any one have any suggestions
I have not noticed any other settings change
3 REPLIES 3
rooobb
Which tv are you dealing with and which FW release are you on?
Paul_Glover
Extra info TV is a 65” A1 has Android security patch 1/9/19 version 8.0.0
software is up to date
i have undertaken a soft reset but not a hard reset ( as I have several setting I do not want to re enter again
rooobb
You can fid the actual fw release info by pressing the HELP remote menu button. In any case you are not on the latest that can be found here https://www.sony.co.uk/electronics/support/oled-tvs-android-a1-series/kd-65a1/downloads/00016668
