Macro-blocking from CAM module returned for XH90
profile.country.RO.title
aimesilenz1
My XH90 (KD-55XH9096) started to experience the macro-blocking and stuttering problem while CI+ card is inserted. The problem appeared with update v6.2126. The newest update v6.2146 did not resolve the issue. I know that the problem should have been resolved in a previous update, although I hadn't experienced it myself until now. Has anyone else encountered this after the recent updates? My local Sony support (Romania) wasn't very helpful and recommended me to contact a repair shop (even if it is a known issue with the CAM module) or wait for a new update which may or may not include a bug fix (asked them to forward it to a specialized department, but I don't think they will).
21 REPLIES 21
Gabrielgxa88
Yeah, you're right, i wasn't thinking that far... 🤦‍♂️
I've tried to find the edit button... 🤔🤔
Finally I've reported my post as inappropriate...Will see if someone is going to delete my post. Have a good one...
P.s.:Back to topic. I've just changed my CI+module with a Hd receiver. The inconvenience is that I'm using 2 remotes and the 4k channels stil don't work. Hopefully in short time the provider is going to develop a 4k reciever and solve this problem 100%.
SadSonyUser
I have the same issue, on DIGI Romania. It;s so bad that I cannot watch anylonger any show. I was thinking this was about the s1gnal quality, but in the same home, same cable Digital Terestrial cable,  I have a TCL that is smooth on TV. I;ve reseted all image settings to default, disabled motion flow, all postprocessing on images, still no luck
I have to buy another TV because of this CAM bug..  Youtube and any other android app is smooth, only the TV playback has this issue.
