KD-65X8505C - 1080p/25Hz not supported!!!
B1tK1t
It seems that 25Hz is not supported with a resolution of 1080, while it's working fine on UHD resolution.
I would like to know if anyone encounters the same behavior and can confirm, that the video descriptor is missing from the CEA Extension block of EDID table? Simply asked can you set your TV to 1080p/25Hz? And are other models also affected?
3 REPLIES 3
cass_n
Hi @B1tK1t - I'm not sure of the answer to this one.  If the other community members aren't able to help, you could try asking Support (details here).
Cheers,
C
B1tK1t
I thought that this worked before but I'm not so sure anymore. Cause when I now hook up my PC at 1080p and look thru the refresh rate list, 25Hz is not available.
B1tK1t
FYI. The KD-65XE9005 doesn't support it aswell.
