KD 55ag Oleg tv
Trevor1544dog
KD 55ag Oleg tv
Has anybody had the the issue with the tv keeps coming up in top right hand corner WiFi not connected with a ! But it is connected when checking connection
3 REPLIES 3
Please check if the software of your TV is up-to-date.
This issue should be fixed with the latest version.
If not, you might want to check the clock setting of the TV.
Peter
Trevor1544dog
Cheers been trying to find in settings how do I know if it’s updated or upto date any help on that one please also do you know if the screen can open up to give full picture in movies ?
Joe_Dohn
Specialist
You can find the update version and steps in these links:
v6.7140 for KD-55AG8
v6.5042 for KD-55AG9
I wasn't sure which model is yours so I linked both.
Hope this helps!
- JD
