ITV Hub and missing subtitles
Sceptic10
I have a KD-55AG9 with which I am very happy ....BUT while I can get subtitles on all channels and Apps I simply cannot get them on ITV Hub even though the programme guide states that they are there. Am I alone with this problem or can anyonme help
Tags (2)
11 REPLIES 11
Sceptic10
ITV Hub responded very quickly to my email pointing out that they don't work with Sony on Youview but I can get subtitles if I watch via Roku using my NowTV handset. Problem solved and smiles all round. Thanks Joe
Joe_Dohn
Specialist
Glad I could help and thanks for marking your post with the solution ^^
Now others can find the solution easily thanks to you!
- JD
