Hi I have a home video on USB (H.264 mp4) the video plays just fine but when I launch the initial screen to select the move to play there is a separate blank file alongside my video thumbnail with same title but if selected won't play. The video itself plays fine but it is annoying to have blanks alongside. Is this normal or is there anyway to delete the blanks.
Regards in advance
go to settings, apps...... find video player there and delete cache and maybe data. That happens because for some reason your drive actually change name and then you end up with more of the same files in the database.
Fantastic, your solution solved my issue.
Thank you very Much.
Kind Regards and Merry Xmas
