Hello, I finally got all the pieces together in my HT setup but for the life of me I can't get ARC to work. I'm trying to watch a Netflix movie on my TV but I want the audio to come out of my receiver/speakers...so far no dice...I can only get the audio to work out of the TV speakers...maybe I'm missing a step on the setup...Any help on the correct setup is greatly appreciated. Thank you
TV: Sony XBR-65X850D
Receiver: Marantz SR-5010
HDMI Cable: Wireworld Chroma 7 (HighSpeed w/Ethernet)
have you checked?:
Manolo
Thank you Manolo, I'm trying to get the audio to the recevier via the HDMI cable, HDMI port #4 ARC not via the digital audio output...or are you saying that I still need to go to the digital audio settings?
I would say yes, my answer comes from here:
http://helpguide.sony.net/tv/cusltn1/v1/en-003/contents/TP0000628063.html
Manolo
I have a system with a Marantz NR1403 receiver and one thing you must do to get ARC to work is enable HDMI control. For me in setup I entered: Video - HDMI Setup - HDMI Control [On]. I believe there may be other HDMI settings available for you on your receiver which you will have to make a judgement call on. When HDMI control is enabled your receiver name should appear in the TV setup under Bravia Sync Settings - Bravia Sync Device List.
Thank you, I will try that.
Hi @fcienfuegos
Im glad you managed to get it working. Would you mind replying back with the make/model of the cable box that has the issue?
Its so I can add it to the end of this thread that I created:
https://community.sony.co.uk/t5/televisions/hdmi-problems-troubleshooting-steps/m-p/2141941
