Is this Color banding or Macro blocking?
im comparing 2 pics from same source you are saying are low bitrate SDR
But you obviously don't have any answer, why one picter can handle color banding, the other can't with same source, but different TV!
I don't have a clue on how you did get those picture on your camera and which TVs you are comparing and how they are set. In any case if your point is that the XH90 doesn't have a smooth gradation feature this is true and you should know from the beginning that it is a a cheaper set that support 4k@120Hz without having the same video processor of more expensive set like XH95.
And remember that I am here to try to help out not to be attacked by you, I didn't sell you anything
Im the one been attacked about my english
