hi guys i dont wont to update to the youview as i am happy with my tv as it is
can updates be turnd off ??? or do's the tv not auto update do;s it need to be done manually ?
kind regards
fether
Hi there
Yes you can turn OFF automatic updates. However, at some point when the next update occurs, YouView will be installed anyway. Even if YouView is installed, you dont actually have to use it
Either way to disable auto updates
