Best 4K player for Sony Bravia KD55XD8599
Nozyspy
Hey there, i was wondering if anyone could advise me on what the best 4K player to get would be for my Sony Bravia KD55XD8599.
I have been looking at both the UBP X800 and the UBP X700. However since my TV is not one of the ones that has got the Dolby Vision update (and it doesnt look like it is going to) is there really any advantage to getting the X700 over the higher end and and better build quality X800?
The extra cost of the X800 isnt a huge issue, i just want to make sure i get something which is good quality and playes 4K and upscales Blu Ray as well as possible.
Any advice would be much appreciated! :slight_smile: (I hope ive posted this in the correct forum!)
Nozy
3 REPLIES 3
Nozyspy
Any ideas? 😕
IamNic
Hello @Nozyspy,
I own the UBP-X800 and I am very satisfied - hope this is of any help :slight_smile:
- Nic
Nozyspy
Thank you!
