Where to buy A6000 in WHITE?!
profile.country.IE.title
KellyLynch
I am on the hunt for the Sony A6000, but specifically in white
I am based in Dublin, but have no problem buying this in the UK or Europe. I have not been able to find it on any Irish websites or in any of the camera shops here in Dublin.
Any advice or direction would be greatly appreciated!!
Thanks,
K
Tags (2)
KellyLynch
Thank you for this! I actually ended up buying it from Amazon.de and it came in at less than €640 all in (delivery, etc) last September. Slightly more expensive now though I think for anybody currently looking!
https://www.amazon.de/dp/B00PCDQSJM/ref=pe_386171_145348981_TE_item
2 REPLIES 2
gadjobeen
Amazon.co.uk in the U.K have the white model available. Currently only 3 left in stock and it is sgnificantly more expensive than the other colour options @£652
https://www.amazon.co.uk/Sony-ILCE6000LB-Compact-SELP1650-Electronic/dp/B00PCDQSJM?th=1
KellyLynch
