Tethering shooting via cable iPad
Luigigalasso
Dear all, is there the possibility to connect the alpha 7r3 to ipad via usb and shooting ? Without the WiFi connection. I tethered the camera from my laptop using a usb-c type cable and it worked out. I wonder if I can do the same using the iPad. I know that I can connect the camera to ipad using the app edge mobile - WiFi, but the connection is not stable, so maybe via usb is much more reliable.
thanks
1 REPLY 1
To my knowledge this is not possible. I found several articles around how to use your iPad as a monitor but transferring images to your iPad seems to be impossible due to restrictions on the iPad side.
Peter
