is anyone else having focus problems with the 200m x 600mm very slow and sometimes resets its self then focuses
what camera are you using
Hi quickklik,
You could always try contacting Sony Support about this to see what they suggest?
Thanks,
Pascale
sony a7r1v
i asked what camera you were using because a friend was using a sony mark 111 with same problem i tried to replicate it on my sony a9 but the lense worked just fine since that time he has said it has been okay so you could maybe try your lense on a different camera hope this is of help to you all the best madge115
thanks for quick reply i have changed camera's now to the Sony A9Mark 2 no problems with the 200x600mm lens at all thanks
so glad you have solved your problem i think you have a very good combo with the a 9 enjoy your photography all the very best i have been very happy with the 200-600 madge115
not sure if you got the Red Deer that is the quality im getting now
sorry never picked up on the photo you have got to be very happy with that shot beautiful all the best madge115
