Sony 200mm x 600mm focus problem with 2x teleconverter
quickklik
is anyone else having focus problems with the 200m x 600mm very slow and sometimes resets its self then focuses
Quickklik
13 REPLIES 13
madge115
what camera  are you using
Pascale_F
Moderator
Hi quickklik,
You could always try contacting
Sony Support about this to see what they suggest?
Thanks,
Pascale
quickklik
sony a7r1v
Quickklik
madge115
i asked what camera you were using because a friend was using a sony mark 111 with same problem i tried to replicate it on my sony  a9 but the lense worked just fine  since that time he has said it has been okay  so you could maybe try your lense on a different camera  hope this is of help to you   all the best   madge115
quickklik
thanks for quick reply i have changed camera's now to the Sony A9Mark 2 no problems with the 200x600mm lens at all thanks
Quickklik
madge115
so glad you have solved your problem i think you have a very good combo with the a 9   enjoy your photography  all the very best   i have been very happy with  the 200-600     madge115
quickklik
not sure if you got the Red Deer that is the quality im getting now
Quickklik
quickklik
Quickklik
madge115
sorry never picked up on the photo you  have got to be very happy with that shot beautiful  all the best      madge115
