There is a plastic ring inside this lens where three small plastic flanges hold the lens unit in place. One of these small flanges broke thus making the entire lens useless. What is my best option of replacement with a different lens - I simply do not trust that 1650 design! Michael
What's the model of the camera you are using?
Regards,
Gladio
NEX-5
I found a like where you can view the best lens categorised for your camera and see images with these lenses in the link here. I'd recommend checking the replacement option with the retailer if possible, but if you're looking for another lens, this link might help.
Cheers,
Gladio
