Lens adapter
Lens adapter
I have an alpha 77ii DSLR which uses the A mount system but is there an adaptor that would allow me to use the E mount lens as I am hoping to rent a long zoom and all I can find are for the E mount system.
1 REPLY 1
Joe_Dohn
Specialist
It seems that you can't use E-mount lenses with this model, Sony doesn't even list an adaptor on their compatibility page.
