A-37 in-camera sharpness control?
profile.country.en_GB.title
Flying-Compass
Ive recently bought an A37, this is my first DSLR, but ive used Minolta Dynax film SLRs for many years.
Im finding that the results with the 18-55mm lens are a little soft right off the bat, although the images generally are smashing. Ive heard it said in various reviews of this model that there is an in-camera sharpening/sharpness control that can be adjusted, but I cant find it.
Can anyone confirm this exists and if so direct me to the controls?
Martin
4 REPLIES 4
Mick2011
HI Martin, welcome to the Sony Forums :slight_smile:
You should be able to access the Sharpness adjustment, along with Contrast and Saturation, by pressing the [Fn] button and selecting [Creative Style].
Mick
profile.country.de_DE.title
cmosse
Contributor
Hi
please also note that you can greatly improve the performance of the lens by stopping down the aperture 1 or 2 F-stops. Therefore, when there is sufficiant light set the camera to A-mode and select an aperture like F8 or so, instead of F3.5 (camera will often use the widest setting in AUTO mode.)
Flying-Compass
Mick,
Thanks, setting found. I see its adjustable +/- 3 levels. If put it up to 2 and will take some comparision shots next time im out and about.
I'd expected to find it in a 'technical' menu option, I hadnt though of it being in the creative options.
Cmosse - Im alreaady in full manual. I only use auto when being in manual isnt convenient (parties and the like, when I dont always have time to compose a shot how i'd like it). The sharpness issue was actually most noticeable on a well stopped-down series of shots of local churches, where I was heavily stopped down to get the requiered DOF.
almokdad
hi, thanks for your post, i bought this camera 2 days ago and i was about to post the same question when i encountered your post. i couldn't find the answer in the manual, and i'm finding the controls ( menues) a bit fiddly if you know what i mean  (not so straight to the point).
great camera though
thanks again
