VGN-AW11Z mouse problem .
profile.country.SE.title
heavydiver
I got this computer i upgrade it to windows 10 my mouse still function but after a time it stoped to work.
Its no wrong with mouse or usb ports i tryed with memorys .
i had help from a program suppliers of reimage . they fixed it but now i have the same problem i tryed different types of program  nothing helps. im so tired of this now . is it anyone who knows how to fix it?
Peter
Tags (1)
4 REPLIES 4
Hi Peter,
Have you checked the hardware manager? Do you see any device with an exclamation mark?
Maybe you have to update or change a driver.
Peter
heavydiver
Yes i can see this but i cant upgrade the drivers
How to do?
Thanks peter
Skickat från myMail för Android
Joe_Dohn
Specialist
I couldn't find any driver downloads on the support page, but it might be that this vaio doesn't support Windows 10 in the first place, though I was unable to check the article for it as it doesn't seem to exist somehow?
heavydiver
Hi
Yes i looked the same page.
I really dont know what to do.
I had this problem Before i got it solved .
But now its back i wish i know how that person solved it but to have that help i need to pay lot of Money
Br Peter
Skickades från E-post för Windows 10
