SanDisk Memory Stick Pro Duo to SD Adapting
rainbowandghost
Hey, So I have a old camera of mine that had a Memory Stick Pro Duo as its memory card, I want to get the pictures on it off so I can sell my camera but I can not for the life of me find an adapter for the Memory stick pro duo to an SD Card, I don't want to just lose these photos as I have a ton of childhood photos on here. Any suggestions? (if it helps at all the type of camera is a Sony Cybershot)
1 REPLY 1
Blencogo
You will probably need to buy or borrow a USB Memory Card Reader and transfer to SD through a PC.
Make sure the reader you use supports both formats. Probably £5 will get one from Amazon.
https://www.amazon.co.uk/REALMAX®-Multifunction-Aluminium-Lighter-Adapter/dp/B01I1NEBE8
