dvd problemes
nabilxp
dvd problemes
hi all
i have a probleme with my vaio dvd palyer;
i cant read or write dvd into my vaio !!
what can i do ??
pls help:smileycry:
7 REPLIES 7
profile.country.en_GB.title
kee-lo_
Arreter de poster en double, ca aiderais!
nabilxp
j'arrive + a lire mes dvd ,j'ai reinstaller tous mais sans effet
:cry:
j'ai pas poster en double !!
kee-lo_
Oui, t'as poster en double, un reply a l'autre poste.
Qu'est ce que tu as changer depuis ca ne marche pas?
nabilxp
ok desolé !!
peux tu m'aider,
j'arrive + a lire mes dvd.
j'ai winxp sp2 ,le fimeware DVRK12VA du lecteur est installé.
j'ai reinstallé mon system 2 fois mais sans resultat !!
aussi j'arrive + formater un dvd rw !!:smileycry:
Dfcapkin
You should setup nero and you have to know your dvd support what kind of dvd.
nabilxp
thanks but the brobleme that i have is that i can read dvd !!!
:cry:
Awong
I have the same problem, 😞 looked on the forum and its seems to have something to do with sp2, think your ment to upgrade firm where before installing sp2 otherwise theres conflict.
let me know if you find a solution I'll keep you posted on my progerss.
Andy
