Audio CD's to DVD
Lancedrlot
Audio CD's to DVD
I'm a newby so forgive me if this question is naive.
I have been trying to record a 4 CD audio boxset onto a blank Memorex 4.7GB DVD+RW disc, using SonicStage software that came installed on my PCG-K215K with its Matshita UJ -820D CD/DVD read/writer, but have been unsuccessful.
Am I barking up the wrong tree?
Thanks for any info.:smileysad:
13 REPLIES 13
profile.country.en_GB.title
kee-lo_
Yep you are
Unless I misunderstood, it's a DVD-A you want to make?
Remember copying CDs you don't own the copyright cannoy be discussed here.
Lancedrlot
Yep you are
Thanks for your response.
I have already purchased the boxset and simply want to combine the 4 CD's onto one DVD disc so that I can play it uninterupted on my home audio DVD player without the need to change the discs. I do not think there will be any copyright infringement in these circumstances.
I would be interested to know if this can be accomplished. So it's a DVD-A disc I need, right?
kee-lo_
Ahh I see, not sure you can do it, not many DVD writing apps allow the writing of DVD-A yet
Maybe Nero does this...
Lancedrlot
OK,
Many thanks.
feederfan
You could just burn them as mp3s to a CD, most new DVD players will play mp3 CDs. As long as you use 256Kb/s Mp3s you will not be able to tell the difference
Lancedrlot
OK thanks,
So in MP3 format I should be able to get 4 CD's on 1 disc, right?
kee-lo_
Easily
feederfan
You should be able to get 250 tracks on 1 700MB CD, if the tracks are 3 mins long at 128kbs, in your case, 256kb tracks, you should get 125 tracks on a CD, so about 10 albums :slight_smile:
kee-lo_
If you only want the box set on there rip at 320kbps.
