KDL-50W705B MediaPlayer Error
MediaPlayer Error. TV try to open Media Player and after few second FC. Before can play 1 week or 1 month without any errors. Sometime help full tv reset, sometime not.
Any ideas?
2 REPLIES 2
Anonymous
Hi there
Can you please describe your problem a little more - as its hard to know what you are meaning.  Can you describe more about your setup - as in are you trying to stream files from your computer or a USB drive?  The more information you can provide, the more likely someone may be able to help.
I'll try to explain ... After the last reset TV to factory settings already 2 days all is ok.
And so, when trying to choose from the application menu Media Player, just error. Does not even choose the source. It doesn't matter, it's a computer or usb flash drive.
