KD49x8505bbu Wont link audio to Bluetooth Headphones
studavie61
Is there a way to send the audio via bluetooth to my headphones.
My headphones link to my phone (Android), my laptop (Linux, Windows) and other devices.
When I search from the Sony TV id does not find ANY devices.
Regards
Stuart
Anonymous
Do Sony make mice?
I think any mouse will do, that confirms with Bluetooth v3.
"Only Bluetooth mice (up to Bluetooth v3.0) can be registered to the TV. You can register up to 2 mice."
3 REPLIES 3
Anonymous
Hi there
The bluetooth on the TV, is ONLY to link to computer mice.  It cannot be used for any other function unfortunately.
studavie61
It would have been nice if that had been made clear on screen.
Do you know if it is only Sony mice.
Thanks.
Anonymous
Do Sony make mice?
