can't anybody help me ho to update my device
i see in http://www.sonymobile.com/global-en/software/phones/xperia-zr/ there is update for my xperia zr(C5503)
i try to update direct from my defice but my device say my system is up to date
my android version right now is 4.1.2
than i try to update using PC Companion, this software also saying my device is up to date (ver 4.1.2)
the last one i try is using update service but the result is my device vertion still 4.1.2
does anyboy can help me how to update my xperia xr (C5503)
there's nothing wrong with your phone
just like any other update you have to wait for the update to be approved and released in you country, if your phone is or was locked to a carrier you have to wait for them, your carrier/network, to release it
on your link
Latest available software
You may already have the latest software, depending on the date of purchase. Software updates are released at different times depending on operator and/or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device.
Android version: Google Android 4.2 (Jelly Bean)
Latest available software: 10.3.1.A.0.244
Release started: 2013-07-31
on your link
if you do NOT want to wait then you can manually update your phone
How to manually update, downgrade, root 2013 Xperias
Thank you for the answer
i prefer to wait the update for my country
if you change your mind, the option its above
today, I have got my xperia zr. I m from India. and when I checked the support for my device on sony india page it shows that I should have 10.3.1.A.0.244 this bulid no. But I had 10.1.1.A.1.310 build no. Also when I try to update my device using latest pc companion tool it shows my device is upto date. I dont know what to do. please help
also i have tried using update via wifi..but it shows my software is upto date..
When these updates are available in for india user of Xperia ZR. C5502.
Eagerly waiting for the same...
Please provide some expected date for the same.
will the manual update voids the warranty??
Its supposed to VOID, But you can since you can flash your firmware using flashtool it cant be VOID. in simple words create a back of your firmware before ypu flash any other rom
