hi,
I just bought xperia z. But I am really disappointed about this phone's earphone low volume while call. Then I tested system settings for earphone, the test sound was very clear and pure. But I have problems about hearing call sound. Call sound looks like robotic sounds and comes really low. Please help me, how can I fix this problem. Is this problem belongs software or hardware. What can i about this annoying matter?
I just did a factory reset, good thing I didn't have much on my phone and well it worked after that, now the volume of the call is way too strong haha
i have same problem too and i just got another replacement today...but i think the problem is the design is low...only good with headphones
the phone is water resistance...so dont worry about wet or some cos it is design to even swim with it in the swimming pool and take pics....so that is not the problem and i just got a replacement for same issue but it is still same thing go on after
I had sudden drop of callvolume too.
**SOLUTION**
I did something similar as Gizmoguru. I cleaned the earspeaker with soap and water and than with compressed air and it boosted the volume back to normal levels.
Blocked earspeakerfilter seems to be the problem.
THIS WORKED!!!! Thank you gr8gizmoguru
“ i used a clean dry toothbrush and brushed the earphone grill!! yes you read it right...and guess what?? IT WORKED!! the volume is way higher than before . gr8gizmoguru”
Hi, I had the problem of volume droping whilst on a call, My freind told me to try raising the volume whilst on a call. It worked fine all back to normal now.
Hey drrummer, the toothbrush tricked worked and we haven't had any issue since!! Yay!! Good luck.....
Hello,
Unbelievable, you were right and save my Phone. I was about to throw it away and buy a new one.... hahahahahah
Thanks again.
