Does turning off the phone with the power button (not just putting it in sleep) and turning it back on again cause the phone to reboot?
Are there any other reboots between that and something that restores factory settings?
Thanks
Sorry to bother you all.
I found the power and up volume key for 10 Seconds reset. I think that is what I was looking for.
Press and hold Power Button + Volume Up Key... Release after 1 vibration... your device will restart...
Press and hold Power Button + Volume Up Key... Release after 3 vibration... your device will refresh with shutting down apps, and free memory too... You need to switch back it on
