diegoamv90
SD Card
So, it's not possible to install apps or games into the SD Card. What exactly can I save in the SD Card? With my Xperia Z I also bought the tablet Z but only the 16gb version because I thought i could expand the memory to save games and apps, which I can't.
Zann_H
Enthusiast
16GB is more then enough to hold your games and apps. Unless you plan to have 50 games on your mobile at the same time.
For the external SD, use it to store other stuffs like:
- Photos and Videos you capture from the camera (in the camera settings)
- Audios(just move all your mp3s to SD)
- Downloads (use the lastest ES File Explorer and let it's Download Manager handle all downloads and save to external SD automatically)
- any other stuffs you don'w want to lose incase you need to do  a factory reset.
2 REPLIES 2
Zann_H
Enthusiast
ekingxxx70
after you install your games and apps, download and install andorid assistant. This will then give you optoins to move your installed apps to the SD cards. Hence freeing up your local memory.
Make sure you get a fast class 10 card.
cheers
