Hello,
I've updated my Xperia Z to system software version 10.3.1.A.0.244. When I put my phone on, I get some error messages like 'USB stopped' and 'android.media stopped' or something like that. This will only ocure when my micro sd card is in the phone, the phone doesn't regonize the sd card. When I get it out of it, the phone will reboot.
When I reboot my phone without a sd card, then there are no problems at all. After that with the sd card in the phone again, it doesn't regonize the card.
The PC can read the SD card when it's not in the phone, i formatted it and put it back, still doesn't work. So i asume it's not the card but a software issue.
Does anyone have the same problem? It's kinda annoying :')
It is a lexmark card. But i found the problem. I formatted with Windows, but that isn't the right way to format. Googled other programs to format sd cards and found sd card formatter. And that did the trick. How simple can it be? Pff
Next time with a system update I will remove the sd card first, just to be sure.
Thanks for the help anyway.
Hello Nickdhnick,
I suggest you use the repair function from Sony PC Companion, as it may be a corrupted file from the firmware update.
WARNING: THE FOLLOWING STEPS WILL FORMAT YOUR DATA. MAKE SURE YOU HAVE A COPY OF YOUR FILES ON YOUR COMPUTER OR SOMEWHERE ELSE.
Do this without having your phone connected to the PC:
1 - Open PC Companion
2 - Go to Support Zone
3 - Click Phone/Tablet Software Update
4 - Click repair my phone/tablet
5 - Read the instructions. If you agree, click Next.
6 - Read the following instructions. If you still agree, check the box and click Next.
7 - Now PC Companion will prepare your computer to your phone repair. This may take several minutes.
8 - After this, several phones/tablets will appear. Select Xperia Z (your phone)
9 - Follow the steps to correctly connect your phone to the PC.
10 - Now you just have to wait until it finishes.
11 - After it finished, you can disconnect your phone and turn it on.
If it worked for you, congratulations! You now have a sucessfully repaired phone.
Hope I helped you, have a great day!
- Augusto
Sorry, it doesn't work. Got still the same problem after the restore.
Are you able to test another card in the phone?
What are your thoughts about this forum? Let us know by doing this short survey.
Another sd card works just fine. Weird, what can i do with the sd card now? It is working on the pc, formatted it a few times.
is it a sandisk card? if so i read that sandisk confirmed one of their SD card products had a faliur in it causing mobiles and so unable to regonzie their SD card like it should so you could contact sandisk about it but only if yours is a sandisk card if it's not then you gota contact correct company thats the making of your sd card
