Battery Saving Apps..
xperiaz2
Does the xperia z need any battery saving apps? Since it already has a stamina mode?
I have installed the battery saver app but i want to know if they really make a difference?
As i couldnt make out the difference.
Please let me know if these apps make a difference. And if they do then which is the best one to install on the xperia z
shihstouch
Enthusiast
Normally these kinds of apps slow down your device, so better avoid them, there is a software from the snapdragon processor... You can install this and it will help improving your device in many ways..This is from processor so hope not much bugs...
https://play.google.com/store/apps/details?id=com.xiam.snapdragon.app&hl=en
1 REPLY 1
shihstouch
Enthusiast
